0
0
Stering Wheel and Hub Alignment/Position
All,
Fitting my steering wheel and steering hub.
First, does the alignment of the steering wheel hub relative to the dash look correct in the below pic (i.e. angle toward the PS ?
Second, in terms of fully seating the hub onto the steering shaft, should the shaft fully seat (bottom out) within the hub (it's a tight fit).
Thanks.
