Covering the e-brake hole
My Eastwood Versabend just showed up today so I can start working on a few little sheetmetal tasks. One of these is to cover up the hole for the e-brake handle in the passenger floor since I'll be using an E-Stopp electric e-brake and won't have an e-brake handle. I have a tendency to overthink and overengineer things sometimes, and I've spent a lot of time figuring out how I can fill that hole flush with the surrounding sheetmetal, but I'm wondering if that's even necessary. If I simply make a patch panel that I apply over the hole and attach it with some flush-mount rivets, will that step between the two layers of sheetmetal telegraph through the carpeting or will it totally disappear? FWIW, I'm planning to use the Lizard Skin spray on heat and sound coating under the carpet. I'm inclined to think that the patch panel height mismatch will totally disappear under the Lizard Skin and carpet but am curious what others say.
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
.040 mismatch covered with Lizard Skin (or any other insulation product for that matter) plus carpet? You'll never see it. Especially in that area.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Build thread here.
Why would it need to be flush, with flush-mount rivets? All the aluminum on the car is overlapped at the seams and fastened with pop rivets.
aside from the over-thinking scenario which from time to time I am accused of myself, how do you plan to install the e-stop?
RickP
RickP
RickP
Maybe look at the fiero mod and use the e-stop unit instead of the fiero handle? That puts the unit on the door side of the driver seat vs near the transmission.
JohnK
I have a few ideas on the E-Stopp, but not sure if any of them will work yet. Once I drop in the engine/trans for a test fit I'll have a better idea where it will fit.
CFranks
Dang Craig, that would 100% work.
Build thread here.
JohnK
I wouldn't cover up the e-brake hole until you figure out where and how your going to mount your E-Stop. I looked at doing the same thing and the only option I could come up with (another forum member did this) is mounting it in the trunk. I am running a T5 and even with that, I could not see enough room to mount the E-Stop. I still may go in that direction but interested to see what you come up with.
Well, that ship sailed long ago. I cut the e-brake handle mounting bracket off the frame before I had the frame powder coated.
Build thread here.
JohnK
Mr. commitment I see. Let us know how you get the E-Stop mounted and functioning. It really is a nice product.
Just scab patch that hole with reg rivets, seal it up with silicone. When covered with carpet, NOBODY will be able to tell. Unless you wanna take pictures and tell people, "hey, wanna see what's under that carpet right there?"
Somebody on here mounted the e-stopp on the driver's side of the trans tunnel. I'm thinking about doing what you are and ditching the e-brake handle for an e-stopp.
