Thread: Found in rear differential
    NY
    Anyone know what these are ? Drained rear and out they came
    Those are ears that have broken off of the metal plates in the limited slip assembly. Time to rebuild with new steels and friction discs.
  3. Thanks WIS89 thanked for this post
    NY
    thanks Jeff
    When you look for rebuild kits, the carbon fiber kit is usually not much more than the standard kit so go w/ it.
