Results 1 to 3 of 3
Thread: trouble with the head lights wiring on my 35 truck
    herb fraser's Avatar
    well I can only get power from the tan parking light harness wire and from no where else , and only when I pull the light switch to the first click , and advise would be great , Thanks Herb
    Bourne-Cape Cod, MA
    You must have the dimmer switch plugged in to get any feed to the headlights. The high low beam will not work unless the switch is installed.
    FFinisher/AKA RE63
    Quote Originally Posted by FFinisher View Post
    yep that's the problem , thanks
