Out of Sight Audio
Likes Likes:  3
Thread: Roadster For Sale due to Health
    Member Arvin's Avatar
    Layton, Utah
    Hate to be writing this post but I need to put my Cobra up for sale. If anyone is interested I will get you the specs. I am looking to get in the 50k range.
    FACTORY FIVE RACING #F5R1008271RD Complete Kit
    ALL NEW PARTS!!!!
    Options:
    Vintage Gauges
    3-Link
    8.8 Rear-End with 3.55 Gears
    Standard FFR Disk Brakes Front & Rear
    Dual Chrome Roll Bars
    4 into 4 Headers
    Stainless Pipes
    Nudge bars and Over-Riders Front & Rear
    Russ Thompson Turn Signal
    Ron Francis Wiring Harness
    Secondary Fuse Panel
    Heated Seats
    Cobra Earl Fresh Air Supply
    Wipers
    Oil Temperature Gauge
    Alex Glovebox
    Stainless Cup Holders
    Cobra Emblem on Trunk, Hood, Steering Wheel, Gear Shift
    Replica 427 Gear Shift from Finishline
    Cobra Floor Mats from Finishline
    Custom Theft Deterrent System (Been Tried but never Broken)
    Finishline Door Panels
    Rear View Mirror with Slider & Center Rod
    Meatballs
    Sponsor Decals
    Powder Coated Chassis
    Wind Wings
    Sun Visors
    Breeze Angled Steel Frame Seat Tracks
    Battery Cut-Off Switch with Bypass
    Engine:
    351 Windsor, Bored & Stroked to 408 Keith Craft Racing
    Dynoed at 512 hp & 534 ft-lb
    AFR 185 Heads
    COMP Cams
    COMP Pushrods
    Melling Oil Pump
    Edlebrock Performer Intake
    Mahle Pistons & Rings
    Eagle ESP Crank
    Scat Rods
    Moroso Front Sump Oil Pan
    Edlebrock Aluminum Water Pump
    Ford Racing Hydraulic Roller Lifters
    Ford Racing Timing Set
    ARP Fasteners
    Fel Pro Gaskets
    Moroso Plug Wires
    MSD Distributor
    MSD Coil
    MSD 6AL Ignition
    Black cobra Valve Covers and Air Cleaner
    March Brackets and Pulleys for Flat Belt
    Oil Cooler
    Breeze Upper and Lower Radiator Tubes
    Breeze Radiator Shroud
    Relocated Oil Filter
    Breeze Battery Tray
    FAST EFI
    Electric Fuel Pump
    Transmission:
    Tremec TKO 600
    Quicktime Bellhousing
    RAM Clutch
    RAM Steel Flywheel
    Hydraulic Clutch
    Wheels/Tires:
    Halibrand Replica
    315/35ZR17 Rear
    245/45ZR17 Front
    Nitto NT555
    Bodywork & Paint:
    Jeff Miller
    Guardsman Blue & Wimbledon White
    Other Work:
    Clear Powder Coated Aluminum Panels
    Rivets on 2 Centers
    FFMetal Firewall Forward
    Under Dash Panel with two (2) 12-volt power points, heater vents, seat heater switches, fresh air switches, FAST computer hook-up, I-Pod interface, (2) 1 tweeters, (4) programming buttons for tach/fuel/clock/speedo, volume control of I-Pod
    Second Skin Audio Damplifier Pro Noise Reduction Cockpit and Trunk
    Second Skin Audio Damplifier Pro Thermal Insulation Footbox & Transmission Tunnel
    Carpeted Trunk
    400 watt Rockford Fosgate Amp
    6-1/2 Marine Grade Polk Audio Speakers, 1 Tweeters, External Crossover
    False wall in trunk to hide roll bars, seat harness, amplifier
    Dual Pusher Cooling Fans
    Trunk Prop Rod
    Forte Mechanical Fuel Linkage
    LED Lights for Cabin and TrunK
    FFR Complete MKIV Kit (#8271)
    Ordered: Jan 21, 14, Registered: Aug 19, 15
    408 Keith Craft Engine (512 hp, 534 ftlb), Tremec TKO600, Fast EFI, 8.8 Solid 3.55:1 Rear End, FFR Replica Halibrands (9 & 10-1/2"),
    Dual Chrome Roll Bars/Bumpers/Polished Exhaust, Guardsman Blue with Wimbledon White Stripes
  2. Likes JL1958, Todd00000 liked this post
    Mar 2019
    That's a masterpiece. Good luck with the sale. I'm sorry that you are having to let it go.
    Sorry to hear about the sale. I'm lazily shopping for a FF. I'll reach out after end of June if it's still around. What is it titled as?
    Dec 2019
    good afternoon sir, is this car still for sale?
    Dec 2019
    Hello Arvin,
    I hope this message finds you well. I noticed a UT plate on your roadster, is it still available? Im looking for a turn key car and live in North Salt Lake. Would love to come check it out.
    Thank you,
    Adam
    Member AdamIsAdam's Avatar
    Dec 2019
    Long Island, NY
    Is this car for sale still?
    --Adam (different Adam)
  8. Likes Derald Rice liked this post
  9. #7
    Jun 2019
    Still for sale?
