Results 1 to 10 of 10
Thread: Throttle linkage completed
Threaded View
    I continue to plug away on things. Yesterday, I was able to get the mechanical throttle linkage set up, amongst other things. This is one of Forte's kits. The pedestals are secured through the firewall to a reinforced piece of angle that is riveted to the frame.
    I'm using the Russ Thompson throttle pedal.
    I did have to clearance the top of the lever arm a bit to avoid any interference.
    With it set up this way, the throttle pedal bottoms out against the stop at WOT at the carb. Please let me know if you see anything I need to reconsider. Thanks.
    --Nathan
