Aloha experienced builders......is there a trick to getting the AC hoses onto the fittings......I am having quite a fight.
Nevermind........trying to put the slightly smaller hose on the larger fittings......one of those days...
you should have 3 sizes of hoses and fittings for air cond
plus 2 water hoses
a little refrigerant oil on fitting and maybe clamp fitting carefully and push hose on
\got all the right parts and sizes???
Yep, I didn't pull out all the hoses.
