Results 1 to 3 of 3
Thread: Speedometer sensor wire identification help please.
    Mar 2013
    Fort Collins, Colorado
    I thought that I was done with my rewire, but when I took it out, the speedometer was not working. Was in working order when I started this project, so I will assume for the time being that all parts are good. Speedometer and sensor have not been changed. I should have kept better notes, or at least kept my notes where I could find them.
    Speedo is a Speedhut non gps, with a 2 wire feed. Black for ground, and white for signal.
    Sensor is a Ford , plugged into a TKO600, using the plug on the drivers side of the tranny. 3 wires out of this sensor, black, white, and red.
    What are the call outs for the Ford (94-99) sensor wires ??
    Thanks, Derald.
    MK2 #3319.... On the road since 2002 with a lot of upgrades
    Mar 2013
    Everybody back on the bus. Problem solved.
    Red wire from the VSS needed to be connected to B+SW.
    Black VSS wire to black Speedhut
    White VSS wire to white Speedhut.
    Jun 2019
    Quote Originally Posted by Derald Rice View Post
    a diagnostic scanning device that can monitor the different parts of a car click here to find good one for your car
    I also had same problem when the first time i rewired. My experiment is that taking some the pictures and stick the cable before removing any wire .
