Results 1 to 7 of 7
Thread: Alignment Question
    Senior Member NC Cobra's Avatar
    Mar 2019
    Alignment Question
    Forgive the newbie question but I’ve just purchased a Mark 4 Cobra and it looks like it’s going to need a front end alignment to adjust the toe in on the front end. I’ve been reading quite a lot about how difficult it is to jack these cars up and it’s got me wondering if there is any special considerations I need to factor in before I run down the street for an alignment. Any wisdom you guys could share would be appreciated.
    Jeff,
    Is your car sporting a manual or power rack?
    The caster settings are a different depending on which system you are running.
    Mar 2019
    I bought Rick Haytons car, # 9058 and has power steering. The car tracks well but the wheel is maybe 10 degrees off to the left. Rick indicated that he thought the alignment might be off a bit so I thought I’d get it looked at before I chewed up tires.
    Manual rack +3 degrees caster- power rack +7 degrees caster
    -0.5 camber
    1/6"toe in
    Quote Originally Posted by NC Cobra View Post
    That is pretty common if your car doesn't have the offset solid bushings that are sold by Mark Reynolds of Breeze Automotive.
    https://www.breezeautomotive.com/sho...ter-and-coupe/
    Alliston, Ontario, Canada
    If it’s just a matter of the wheel being off a bit, 10 Dey is probably 1/4 to 1/2 turn of each tie rod end to fix. Mine was like that when I got it on the road, bit of trial and error, ended up taking 1/2 turn to centre the wheel. Turn both sides the same so your toe adjustment doesn’t change.
  7. Thanks phileas_fogg thanked for this post
    Mar 2019
    Thanks guys. Found some settings on the forum and after a bit of adjustment to the tie rods got everything into alignment.
