The Right Stuff-Permatex removal-Rear End Cover
Hi Guys,
I have a 3 link 8.8 rear end in my MKIV.
I installed a Moser Aluminum cover.
I have a very small leak at the bottom of the differential.
I mean small, about 1 drop, if that a week, but still a leak.
I'm in the stage where I could remove the rear cover or rear end entirely now.
I sealed the Aluminum cover to the rear end using Permatex, The Right Stuff.....so much for that.
What should I do? leave it and check the fluid every month?
Or try to remove the aluminum cover. I was told that The Right Stuff is very very hard to remove.
Any ideas, suggestions and inputs would be appreciated.
Martin
