Results 1 to 5 of 5
Thread: Gauge hole size?
    Kearney Nebraska
    Gauge hole size?
    Hi Guys,
    Getting ready to cut the holes in my dash for my gauges & switches. How much extra do you figure into the hole size for the vinyl covering?
    Serial #9158
    Measure the thickness of the covering (whatever it is) with a micrometer, and add 2X that to the diameter of the gauge. Cut on the slightly small size for a snug fit. Most materials will compress a little.
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    I'd recommend using a piece of scrap and making a test panel...
    You'll get a feel for how the material cuts, what drills/hole saws/etc to use to achieve the final hole(s) you need, and then a little practice on upholstery. It really helped me after I did the final layout work, and then when I bit the bullet and cut the real thing!
    John D. - Minneapolis 'Burbs
    Fairfax Station VA
    x2 on making a test panel. And measure every component you're going to install. I found that the blue indicator light was slightly larger than the green indicator lights. I drilled based on the blue, and my greens are just loose enough to bug me.
    MK IV Roadster #8631
    Kearney Nebraska
    Thanks for the replies guys. I'm planning on using the FFR supplied material. I just dug it out of the box. It's pretty thick. Now I see why everyone dislikes this stuff. I measured about .045" compressed, although I could get it down to .030" if I really squeezed the calipers. I think if I went with .030" it would be an extremely tight fit. Unfortunately, FFR doesn't supply enough extra material to do any trial fits with the material.
    Serial #9158
