Results 1 to 2 of 2
Thread: Headlight power
    Senior Member Triathletedave's Avatar
    Calgary
    Headlight power
    My headlights were working fine, but now I seem to have only partial power to the right side on low beam, and nothing on the right side on high beam. The left is fine in both modes, and the parking and signal lights are fine. I have no electrical experience, so am unsure of the fix. Do I have a burned out relay? All fuses seem to be fine.
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    Quote Originally Posted by Triathletedave View Post
    Dave,
    There is a blue wire with white stripe that runs from the under dash fuse box to the right side headlight. It is the only wire the is related to all your symptoms. Check it to make sure there isn't a bad splice it that wire.
