Results 1 to 3 of 3
Thread: MK4 Upper Control Arm Clevis location
    Cool MK4 Upper Control Arm Clevis location
    MK4 Upper Control Arm clevis question - My picture is taken from the passenger side. I have the UCA installed with the clevis toward the front. I took the drivers side apart as I thought it was wrong. Holding it up together, you can see that when I reinstall the DS one, the clevis will be toward the rear.
    Is this correct? Do I have a wrong part from FFR?
    I don't want to get farther on the front end until I get this figured out.
    I have this all apart as I switched from Mustang spindles to the FFR ones.
    Thanks for any help and advice you can give me.
    Phoenixmsb
    There is not a left and right arm; both are alike so as you discovered one will have the clevis to the front and the other to the rear. I assume that you are aware that when changing from Mustang spindles to the FFR ones the UCA will need to be installed using the side mounts rather than the top ones.
    Jeff,
    Thank you so much for your help! I've moved the arms to the other holes and purchased new bolts and nuts from FFR as I didn't want to trust reusing the old ones after being torqued already.
