MK4 Upper Control Arm Clevis location
MK4 Upper Control Arm clevis question - My picture is taken from the passenger side. I have the UCA installed with the clevis toward the front. I took the drivers side apart as I thought it was wrong. Holding it up together, you can see that when I reinstall the DS one, the clevis will be toward the rear.
Is this correct? Do I have a wrong part from FFR?
I don't want to get farther on the front end until I get this figured out.
I have this all apart as I switched from Mustang spindles to the FFR ones.
Thanks for any help and advice you can give me.
Phoenixmsb
