Results 1 to 2 of 2
Thread: Cooling Fans
    Jun 2019
    Cooling Fans
    I built my roadster back in 2000 and this year the cooling fans aren’t engaging = car overheating. I’ve replaced the relay and checked the fuse in the fuse panel. This didn’t fix the problem. Any other ideas?
    Thanks!
    Carabou,
    You're more likely to get more help in the main Roadster forum, but here are a couple more things to check:
    1. Ground the fan to the chassis to see if it kicks on
    2. What are you triggering the relay with?
    - Theromo switch?
    - EFI CTS?
    Check that whatever you are using for a trigger is good.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
