Thanks Thanks:  2
Results 1 to 38 of 38
Thread: 5.0 HP upgrade input wanted.
Threaded View
    mburger's Avatar
    Punta Gorda FL
    Hi folks. I have a couple thousand miles more on the engine/car than what's in my sig, but here goes. I'm looking for your thoughts/input please.
    WHAT I WANT:
    ~100 more HP over my 240hp at the crank.
    WHAT I HAVE:
    Stock 5.0.
    Going to purchase a GT40 tubular intake and correct lower for the 302 (NOS) (Thanks again!!! you know who you are)
    I don't like the looks of the 5.0 intake, even the looks of a TFS top end, and the tubular intake is the best looking. (IMO)
    While I don't want to spend $1,600+ on heads, it looks like that is the route I would need to go. I don't want to change my headers, so the heads need to work with what I have.
    Thinking of using an E303 cam and while it's a decades old cam grind, it seems it fits the intended use of the car which is performance street.
    I'll upgrade to 24# injectors and 75mm MAF. I already have a 190lph fuel pump.
    I've had a machine shop tell me anything over the stock 240hp would require changes to the bottom end which I find hard to believe.
    I know there are lots of articles out there about adding HP to these 302s, but it seems to add ~100HP will end up costing many thousands by the time I'm done.
    I'm definately using the GT40 tubular intake but beyond that, I'm open to suggestions from those of you that have been down this road before.
    I'm not interested in nitros.
    Thanks for any input!
    Mark
