Results 1 to 1 of 1
Thread: MK4 Roadster Nightmist Blue_Sold
    Beacon Falls,CT 06403
    SOLDS...SOLD..! *******You can jump into this car and drive the Gumball Rally to California...it's that Good...…...This impressive 2019 Factory Five MK4 Roadster...Vin.# F5R1009515RD…………...was finished 3 months ago... built with all New Parts... I have logged 440 break in miles on the engine.....The car has never been raced or abused.........Registered and Titled in Florida as a 1965 Cobra Replica...,...............there are no donor parts.......…there is a Box Full Of Receipts.......all issues have been sorted out...…no oil leaks......the lights...signals..horns..backup lights.....brakes...parking brakes ...wipers....gauges all work like they should.......…........…
    …..............The MK4 is painted a 1967 Ford Nightmist Blue/w white stripes + High Gloss Glamour Clear ...The Paint is Beautiful..............car won Best in Show at the Lion's Club of Seymour, CT Car Show on 08/29/2019
    …….." Heart Of The Beast " This 393 Ford Stroker Engine has been assembled with the best parts available …..combined with 50 years of Ford High Performance background that went into this Powerful and Streetable 351 Wiindsor Engine. ….it is not your run of the mill rebuilt small block Ford engine..... We started with a standard bore 1969 Ford 351W block ….it was bored .030 over ...…..then Magnafluxed ….Pressure Tested and Assembled with a Scat 393 Stroker Kit #1-94256 ... 10-1 Icon Forged Aluminum Pistons.....Pro Series Rods... 2.02 Aluminum 62CC Heads...Lunati BareBones Camshaft and Lifter Kit # 1035010LK ….290 Degree Duration 496/520 Lift...…...Professional Products Typhoon 4BL Dual Plane Intake...Holley 750 CFM carb... MSD 6AL Digital CD Ignition Box + Distributor...Summit Racing Harmonic Balancer....PowerMaster XS-Torque Mini Starter.........all the machine work...blueprinting and balancing was performed by Brian at Center Auto Machine Shop..Stratford, Ct ….This Stroker delivers 450HP...…and the power to nail you in the seat...…....New McLeod Tremec T5 2.95 1st gear Trans.....1997 Mustang GT 8.8 Rear Axle...Total Rebuilt with new 3.55 Gears....Truetrac Posi.. Bearings... Seals...Brakes...Rotors....Grizzley 28 Spline HD Axles....Upgraded Factory Five 4_LINK Rear Suspension....BMR Adjustable Upper Control Arms......Koni Coil Over Shocks Front and Rear...…..POWER STEERING********
    ….….…...The Appearance of this Dark Blue Serpent....., The Tight Handling Power Steering........The Roar of the 450hp Ford 393 Stroker Windsor thru the Jones Glasspack Side Pipes.....makes driving this MK4 Roadster Pure Adrenaline .... This Serpent is Ready to be Tamed by it's New Owner...…
    ….A quick list of extras included with this Factory Five MK4 are the Whitby Black Tonneau Cover.....CoverCraft Indoor -Outdoor Cover......Cobra Ceramic Sidepipe Covers.....WindWings.... Tinted Sun Visors......Dual Mirrors....Cockpit Vent Fans....Cockpit lights.....Cigarette Lighter.......Adjustable Drivers seat.........Pneumatic Hood Lift.......Pneumatic Trunk Lift .......Windshield Washers.....HRE Leather Rear Fender Spats....Two Fire Extinguishers ...........updated photos will be added shortly******
    ...….all work completed with the help of an experienced mechanic.......it would cost you $55,000 to duplicate this MK4 Roadster..........Final Price Drop*** $39,000....This MK4 Cobra is presently being stored in Beacon Falls, CT......It will be transported to Florida in November.............Serious Inquires Only****if you are in the Market for a Quality built Cobra Replica....that is the center of attention at the car shows........then this MK4 should be on your list........ .Call anytime to make an appointed to see the car ......... sold without a warranty....…...This car was built from a kit developed by Factory Five......each builder has various methods or techniques that he applies to building one of these cars.......I would not consider this a High End Cobra build.....this MK4 was build with all new quality parts....and attention to Detail + Safety...….the new owner can at any time upgrade the Performance of this MK4 Roadster by installing Brembo 13" Brakes.....Gas-N 4-1 Stainless Steel Headers ….TK500 transmission...….Fuel Injection......3 -Link Suspension..... and you will have an exceptional Cobra......[ click on Craigslist link for 24 pictures of the MK4 ]...…[ click on YouTube link.....video of the MK4 Walkaround & Drive by.. ] Partial Trades Considered.... Thanks for Looking....Joe cell # 1-352-586-6786 ……………….. I'm selling this car to Finance a New Project …..
    Here's a partial list of the new parts used to assemble this 2019 MK4 Roadster Kit :::
    1. FF5 MK4 Base Kit.. Powder Coated Chassis and polyester Fiberglass Body
    2. Upgrade Upper + Lower Front Tubular Control Arms...
    3. Mustang 1990 GT Power Steering Rack with Chevy Power Steering Pump..
    4. 1995 Mustang GT Spindles....11" Rotors and Calipers...Scott Drake Stainless Brake Lines..
    5. Heavy Duty Factory 5 Radiator with Auto Electric fan
    6. 17" X 8" Front American Racing 527 wheels with Tribar Spinners
    7. 17" X 9" Rear American Racing 527 wheels with Tribar Spinners....
    8. Mickey Thompson Street Competition Tires 245/45 x17" Front + 275/40-17" Rear
    9. Koni Coil Over Adjustable Front + Rear Shocks....
    10. 1997 Mustang GT 8.8" rear with new 3.55 Gears...Bearings..Seals...Truetrac 28 Posi Unit..
    ……4_Link Factory 5 Upgraded Rear Suspension....
    11. Grizzley 28 Spline HD Axles...
    12. 1997 Mustang GT Ford Rear Calibers + 10.5" Rotors...Scott Drake Stainless Brake lines
    13. BMR Adjustable Rear Upper Control Arms....Factory 5 Aluminum Rear Lower Control Arms..
    14. New Tremec T-5 [McLeod 1352-000-251 ] 2.95 1st Gear 5_Speed Trans. ..purchased from Jegs
    15 New Excedy Mach 350 Stage 1 Clutch + Pressure Plate...10.5"
    16. New Ford Aluminum Bellhousing
    17. New Ford 28oz All Steel FLYWHEEL...[ Not Iron ]
    18. New 16 gallon Mustang GT Fuel Tank and sending unit...
    19. Denny's Aluminum Driveshaft..
    20. 1969 Ford 351W Block Bored .030 Over Pressured Tested and Magnafluxed by Center Auto Machine Shop
    21. Scat 393 Stroker Kit #1-94256 with 3.850" crank stroke …. Icon Forged Aluminum Pistons...10.3 -1
    22. Pro Comp 2.02 Aluminum 62CC Heads... 10.3-1 Compression
    23. Comp Cam 1.7 Roller Rockers
    24. Lunati BareBones Camshaft and Lifter Kit # 1035010LK ….290 Degree Duration 496/520 Lift
    …..Engine Assembled ….Balanced and Blueprinted by Brian at Center Auto Machine...Stratford,CT
    25. Professional Products Typhoon 4bl Dual Plane Intake..
    26. Holley 4160 750 CFM Carb..
    27. MSD 6AL Digital CD Ignition Box + Distributor
    28. MSD 8MM Wires...
    29. Holley High Volume Mech. Fuel Pump..
    30. 100 AMp Ford Alternator..
    31. Billet Alternator + Power Steering Brackets....Matching Billet Pulleys
    32. Tall 351W Aluminum Valve covers..
    33. Speedway 12 Circuit EZ Wiring Harness...fuse panel.
    34. Finish Line Windshield Wiper Assembly.
    35. VDO Tach and a Basic Gauge Kit.....includes a GPS Speedometer..
    36. 5.0 Shorty Headers/J-Pipes
    37. Raydot Racing Mirrors...
    38. Factory Five WindWings
    39..Professional Products Typhoon Dual Plane 4bl Intake....…...
    40..Tribar Halogen Headlights
    41. Covercraft Car Cover
    42. Melling High Volume oil Pump + Pickup
    43. Summit Racing Steel Oil Pan
    44. Adjustable Black Vinyl Drivers Seat*******
    45...Jones 26" Glasspack Custom Sidepipes with 3" Cores......
    46. Factory 5 Hydraulic Hood kit....
    47..Factory 5 Tinted Visors..
    48...Ceramic Sidepipe Covers""" Nice
    49...Whitby Black Tonneau Cover"""" Nice
    50 ..Summit Racing Harmonic Balancer
    51. ATTWOOD BLOWERS**HIGH VOLUME Cockpit Vent Fans.. Driver + Passenger
    52. Cockpit Courtesy Lights...
    53 .Trunk Piston Lift Kit...
    54. HRE Leather Fender Spats..[ Included & optional Install by the Buyer ]***
    55. Electric Windshield Washer.....
    56 PowerMaster XS-Torque Mini-Starter.....300lb of Torque..HD
    NEW YouTube Video..10/20//2019
    https://www.youtube.com/watch?time_c...&v=krMk2E-nvtE
    https://www.youtube.com/watch?v=LBu-5Jk3XYo&t=61s
    https://newyork.craigslist.org/fct/c...998027785.html
