5
fuel filter for carbureted engine?
My roadster, with stroked 302 engine and Holley 650 DP carb, has a Purolator F63169 fuel filter. I saw some online notes that this is the right filter for injected engines. Is it correct for carbureted engines, too? If not, what's your recommendation for the proper filter (make & number)?
Craig
10/2018 -- acquired Mk3.1 #6602 which was an unfinished project in go-kart stage; 9/2019 -- completed car enough to drive locally and compete in autocross events; still in original black gel-coat; 347 Stroker w/ Holley 650 carb, roller cam; Tremec 3550; 3.51 rear diff; lots of Breeze pieces; 2021 -- XP Champion in Central PA Region - SCCA Autocross Series; 2022 - installed windshield and registered in PA; my Build Thread -- https://thefactoryfiveforum.com/show...ished-Business
6/2022 -- acquired Mk3 #1004; finished build; 347 stroker w/ Holley 560 carb SOLD
