Results 1 to 8 of 8
Thread: FFR Vinyl Dash with Glovebox Questions
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    I purchased FFR's Roadster Vinyl Dash with Glovebox. Mainly for the glove box.
    Messing around with fit and some layout mod's I noticed that the dash thickness doesn't allow for the screw-on bezel for the ignition switch to seat all the way. Anyone else experience this with the vinyl dash ? I assume the solution is to remove some material from the backside ? Anyone have a successful modification to offer ?
    I'm also thinking about covering it with leather. Any one else successfully attempt this ? If so what adhesive to use on this substrate (e.g. Weld wood landau top & trim HHR)
    Any successful experiences with this dash is be appreciated
    I have the same experience with the ignition, but don't have a solution to offer. Another thing to be weary of is the left-most gauge clearance to the body is really tight. Set the dash an 1/8" lower than what you think is right and the gauge bezel shouldn't contact the body.
    Senior Member CFranks's Avatar
    Mar 2018
    Berwyn, PA
    Hi, there was a thread on this topic a few months ago on the other forum, take a look at the below link. I just installed mine this weekend as well and leaving the ring with the gap for now. I’ll torque it down as tightly as possible during final install.
    https://www.ffcars.com/forums/17-fac.../topics/636306
    Senior Member cv2065's Avatar
    Dec 2017
    I used a pair of pliers wrapped with duct tape. Badasp recommended that and it worked. Just be careful not to scratch it up. The threads on all of the switches barely pop thru the new dash. I tightened up the wiper switch from the other side. But once they are tightened, I can’t see them coming loose.
    RJD's Avatar
    Northern Virginia
    I was able to trim some off the back side for the ignition switch but then glued, using JB weld, a thin piece of sheet metal to the back as a reinforcement to the switch. I gave up on the provided toggle switches for the hazards, high/low beams, and windshield wipers, and opted to go with other switches. I used Cole Hersee toggle switches from Del City for the Hazard and low/ high beams - they have longer stems. I added chrome washers to the toggle switches for some bling.
    I used the Ron Francis Synergy Series WS-61 for the windshield wiper switch. The WS-61 is identical in appearance to the headlight switch.
    Some additional notes for the padded dash - I had a stress crack in the dash where the lower supports attach. I resolved this by JB welding thin strips of sheet metal to the dash's inside lower lip. Now the dash support screws attach to metal as well as the dash's vinyl.
    I also added sheet metal backing plates to the back of the windshield wiper switch - the WS-61, and to the steering column hole to support the bezel for the opening to accommodate the Russ Thompson turn signal.
    Overall I like the dash, but it is soft with respect to locking down switches and attachment points.
    Mar 2017
    Thanks for the tip. I will watch out for this them I install my gauges.
    Thanks for the other tips on the install of the ignition switch. Seems like a long way to go to torque it down to flush. I'm glad to hear it's doable. I am inclined to remove some material on the back side and maybe add a piece of sheetmetal to reinforce.
    My toggle seem OK if I don't use the look washer.
    Anybody try to cover this dash with leather ?
    Feb 2018
    Frisco, TX
    Quote Originally Posted by mlewis View Post
    I have to ask, why not just get the blank or aluminum dash instead if you want to cover it with your own leather? I would think the padded vinyl dash is geared more towards people that don't want to modify it.
    Mar 2017
    yeah, in hind sight, perhaps.
    I'm general OK with the gauge layout, I mainly purchased it for the glove box set up and the presumption of fit and possible time saver....
    Just interested in matching the leather in the other parts of the interior....
    sounds like I'm the only one that's tried this ??
