Thanks Thanks:  9
Results 1 to 13 of 13
Thread: Better looking switches
    Cobra Addict AtlantaCobra's Avatar
    May 2019
    Duluth, GA
    Hey folks. Looking for some options for better looking and functioning switches on my dash. turn signal, highbeams, hazards, etc. I have the standard black one way and two way switches but I think they are kinda cheesy and flimsy. Anyone found a good solution?
    Thanks all.
    -Greg
    I used rocker switches with custom engraved backlit switch covers from Rocker Switch Pro. Google them to see what they carry and the custom rockers.
    See if this link works. Backlit switches custom labeled with words and symbols for a truly custom touch.
    https://rockerswitchpros.com/custom-...over-actuator/
  3. Thanks AtlantaCobra thanked for this post
    Likes AtlantaCobra liked this post
    Southport, NC
    Holden Vintage and Classic in the UK.
    I ordered all my toggle switches from them. High quality, rated at 15 amps and look original like the Lucas switches when you add their bezel.
    One of their switches:
    https://www.holden.co.uk/p/toggle_sw...er_4_terminals
    The bezel:
    https://www.holden.co.uk/p/toggle_switch_special_bezel
    Read the bezel page to see if you need the extra threaded washer for matching the hole size as the Lucas and FFR switches use a larger hole. I bought the bezel and the threaded washer to fit the pre-drilled larger holes. You don't need the threaded washer if you are drilling the holes to fit the switch.
    The threaded washer:
    https://www.holden.co.uk/p/toggle_sw...hreaded_washer
    Video from their site re: the switches:
    https://www.youtube.com/watch?v=MZdZKTCa86s
    George
  5. Thanks AtlantaCobra thanked for this post
  6. #4
    Apr 2019
    NC
    Have used these military spec switches on some boats and work well, just not cheap. Military Toggles
  7. Thanks AtlantaCobra thanked for this post
  8. #5
    Senior Member CFranks's Avatar
    Mar 2018
    Berwyn, PA
    I got the Lucas switches from **********, they look a bit better and are more solid than the FFR ones. Just recently installed so I can't speak to the reliability, they have a reputation of being a bit finicky. You also have to deal with the adventure that is the ********** fulfillment process, but you'll get them eventually... If you're looking for a slightly different look than the black toggle and more substantial construction, check out Ron Francis wiring. Several on these forums talk about them. I may swap to them in the future.
  9. Thanks AtlantaCobra thanked for this post
  10. #6
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    Not sure what your layout is.. but.. I opted for standard looking metal switches.. and then put some of those Aviation style switch guards between them. I'm pretty happy with how it turned out. They are aluminum. Got them from eBay.
    All of my control switches are just those toggles, including ignition and headlights. They are not in this photo (can't find one) but I put small black with white letter plastic labels below each switch.
    2016 MK4 | '99 Explorer 5.0 | E303&600cfm carb | T5z + 3.55 | 3-link | SN95 | PB/PS | FR500 17" 315&275 |
  11. Thanks AtlantaCobra thanked for this post
  12. #7
    Senior Member RickP's Avatar
    Boyertown, PA
    I ditched all the included switches and opted for Ron Francis Synergy
    https://www.ronfrancis.com/products.asp?dept=30
  13. Thanks AtlantaCobra thanked for this post
  14. #8
    Southport, NC
    Quote Originally Posted by RickP View Post
    Wow, 35 amp switches. Too bad they don't have black blades. I'd consider painting those paddles black with the 35 amp rating and eliminating a relay or two.
    George
  15. #9
    RJD's Avatar
    Northern Virginia
    I used Cole Hersee toggle switches from Del City for the hazard and low/high beam lights - added chrome washers to them for a little extra bling. I used the Ron Francis Wiring Synergy Series WS-61 for the windshield wiper switch.
  16. Thanks AtlantaCobra thanked for this post
  17. #10
    Maumee, OH
    I went with smooth faced pushbuttons from Billet Automitive Buttons out of Australia. They offer latching and momentary as well. I used them for the horn, fan over ride, and hazard buttons. Turn signals and high beams are controlled on the Russ Thompson hub. I wanted a smooth dash and these will fit the bill. Next step is to drill the new carbon fiber dash this week to get the gauges and switches placed where I want them.
    Scott
  18. Thanks AtlantaCobra thanked for this post
  19. #11
    Parker, CO
    Quote Originally Posted by Sdonnel View Post
    Scott
    I used a pair if their momentary switches for my SDC turn signal setup. Nice stuff and fast shipping from Australia.
  20. #12
    I switched to Cole Hersey also just because I felt they might be better quality. They have several styles including long handle switches and a slip on plastic extension to make a standard handle longer. I use one on my turn signal switch. Scroll to pg 2. They also have a selection of rubber boots and mounting plates.
    https://www.elecdirect.com/cole-hers...e-switches?p=1
  21. Thanks AtlantaCobra thanked for this post
  22. #13
    I used IVS series rocker switches from Car Builder Solutions in the UK. They have several types of switch available. https://www.carbuildersolutions.com/uk/rocker-switches
