Results 1 to 13 of 13
Thread: Can't fill fuel cell
    Junior Member lakeside's Avatar
    Sep 2011
    So, after scouring this forum for a couple of weeks, I'm caving and seeing if someone has had this happen to them. I have a converted Challenge car and can't fill the fuel with gas more than a thimble at a time. My old Roadster also had a fuel cell that was slow to fill, but this one is ridiculous. Maybe pump a couple tenths, then wait til it slowly and I mean slowly goes in and start again. Is this a tank venting issue? Thanks in advance
    I had the same problem with a 22 gallon fuel cell side fill. I removed the rubber flapper in the inlet. Fills without issues now.
    Mike m
    Mike m
    st george, ut
    check your vent. it may be plugged or to small
    Fairfax Station VA
    If it is the vent, Mark Reynolds has you covered: https://www.breezeautomotive.com/sho...eck-valve-kit/
    MK IV Roadster #8631
    Sep 2011
    John, I think the Breeze vent is for a stock Mustang tank, not a Fuel Cell, don't know for sure
    Sep 2011
    Quote Originally Posted by mmoen View Post
    Mike m
    Mike, did you have to unbolt the stub on the side of the cell or did you just stick a knife in the hole and do surgery?
    Fairfax Station VA
    Quote Originally Posted by lakeside View Post
    You are correct; the Breeze vent is for the stock Mustang tank. Sorry if I led you astray.
    Sep 2011
    John, thanks and no worries, I've been astray for a long time now
    Sep 2019
    Can this breeze vent be added without dropping the tank?
    Fairfax Station VA
    You won't have to drop the tank completely, but you will need to lower it far enough that you can get your hand to fit. For me, that would be just a couple of inches. You can easily test by removing the right rear tire.
    Sep 2019
    Thanks John
    Heart of Dixie, Alabama
    Can you run a small hose, 3/8" from the filler neck into the tank and then try filling. Probably not something you want to do daily, but might reveal an issue.
