0
Thanks. I assumed that would be the case. I guess step #1 will be getting a donor with matching numbers. Might be easier if I go with a 96-98 cobra, but every fox body around here for cheap has had parts swapped in and out of it so much I can't guarantee i'll find something with matching numbers. Nicer cars have gone up in value.
If I bought a transmission brand new, would that receipt for the NEW trans be adequate? If so, then I only need to worry about the engine mainly. Obviously no crate motor I assume.
Can I buy the donor, strip it, and then junk it right away? What do I need to retain as proof? Paperwork from the junkyard? Copy of the title? How do I prove to the state police I owned it before I junked it?
