Results 1 to 2 of 2
Thread: (Fixed with logic board swap) More ABS challenges - 95 GT 3-channel module (Help!)
    Member shackf16's Avatar
    Jun 2018
    Tucson, AZ
    So my ABS headache continues. My first ABS module from the salvage yard had 3 of 3 stuck solenoids. It would pass the self-test and the pump will run, but I wasn't comfortable with the idea of heating everything up and smacking it with a hammer.
    I had the salvage yard send me a replacement module, which kind of saved me some work because I had cut the first mounting bracket smaller than I wanted it. The new unit clicks all 3 solenoids and the pump spins up, but it on'tt pass the self-test! (YGBSM!)
    I commenced heating the stuck solenoid unit with my heat gun and gently smacking it with a hammer and got one of them loose, but the other 2 remain locked. Any tips, tricks, or how to videos on how to break them loose?
    So what to do now? Get a 3rd salvage module? Pony up and buy new if I can find one? Can I swap the good electronics portion on the stuck solenoid module over to the functional solenoid one?
    I need to finish this so I can mount it, make up new brake hardliners and move on to the entire wiring harness and new engine...
    Shack
    Jun 2018
    Tucson, AZ
    Fixed it - pretty easy logic board swap!
    After making phone calls to local parts stores and the dealership, I discovered buying new is not an option. There are a couple of resellers on eBay where I could have gotten one, but I wasn't crazy about buying a 3rd used unit. After watching a few online videos about folks who had disassembled different ABS modules to make solder repairs, I figured I'd give it a shot.
    So for anyone else who may run into a similar problem, here is all you need to do. I removed the Torx screws at the corners and the non-tamper proof one along the edge (the one you test the pump motor with) and the logic board easily came off. I simply switch the two boards and put them back together and everything tested fine on my "new and improved" ABS module. Now I have a doubly defective unit to toss.
    Time to move on to the mounting stage...
