Results 1 to 3 of 3
Thread: New Product: PRO-BCM-100/200
    LCD Gauges's Avatar
    Toronto, Ontario
    These features are all available in the Big Brother LCD gauge Systems, but for those wanting to keep their mechanical gauges,
    and nostalgic theme, this is a great module to simplify wiring, as well as add some logic to your vehicle.
    This works with ANY CAR, ANY ENGINE.
    Named the PRO-BCM-100/200 because it acts like a Body Control Module to trigger lighting, pumps, fans, or virtually anything
    you prefer. The device will not interfere with your engine function as it is a stand-alone setup. Minimal wiring is required
    to power and manipulate devices. As shown in the diagram, the interface can be wired for switches directly to the box, as opposed
    to feeding extra wires from the vehicle's electrical system.
    For instance, a single switch wired to ground can control turn signals, and hazards with preset blinking patterns. There is
    no need for flashers, or complex connections. Simply connect the trigger wire to the respective relay. The outputs will
    also drive LED lights without the need for resistors.
    A single sensor can be programmed to activate one or more fans based on input temperature. Use auxiliary fans and
    temperature sampling for transmission pumps, fans, etc.
    Use pressure sensors to run priming sequences for fuel pumps to allocate extra current for engine cranking. May be
    connected to Steering Wheel buttons, or console mounted buttons.
    The system can be setup to run electric water pumps and radiator fans after engine shut down for preset times. This
    is great for boosted cars, or any engine for cool down.
    Either model is capable of sensing out of range temperature and pressure to flash a Status/Trouble LED
    that can be mounted on your dash or console.
    Example of 100 series wiring diagram:
    For the 200 series module, use your Windows based computer to Log information in real-time,
    or troubleshoot the input and output signals. The log files are saved as CSV format that can
    be opened and graphed in most spreadsheets.
    The differences between the 100 and 200 models are listed below.
    Request customized control circuits for your application like window controls, door poppers, etc.!
    Weight: ~ 2 lbs.
    Dimensions: 8" x 5" x 2"
    Temperature Sensor: Autometer 2258, $45 CDN
    Pressure Sensor GM 12616446, $75 CDN
    PRO-BCM-100, $300 CDN
    2 Door inputs [Digital]
    2 Signal inputs [Digital]
    1 Pressure Sensor Input [Analog]
    1 Temperature Sensor Input [Analog]
    1 Shift LED Output
    1 Status/Trouble LED Output
    1 Right Lamp/LED Output
    1 Left Lamp/LED Output
    1 Dome / Courtesy Lamp / LED Output
    Tachometer input [5V PCM or 12V Pulsed]
    PRO-BCM-200, $450 CDN
    GPS sensor
    Customized Circuit capable
    Logging and Test Software for Windows based computers via USB 2.0/3.0
    LED Turn Signal capable
    1 Shift LED Output
    12 Digital Inputs
    10 Analog Inputs
    14 Digital Outputs
    As always, post your questions here, PM, or email!
    Thank you,
    Tino
    Senior Member beeman's Avatar
    Indiana
    Wow, very good pricing!
    Any plan to make it compatible with Android OS?
    GTM #304 LPE 525hp LS3
  3. Thanks LCD Gauges thanked for this post
    LCD Gauges's Avatar
    Toronto, Ontario
    I'm not well versed with Android, but the possibility is there if the demand is high enough.
    Once I get caught up on my current tasks, I'll dedicate some time to learning Android and Apple iOS,
    or hopefully find a programmer that can do the job!
    Additional edits in blue text above.
