Results 1 to 5 of 5
Thread: Firewall installation
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    I'm getting ready to final mount the firewall and foot boxes. Do we use the marine adhesive on these. Wasn't sure with the heat generated in the engine bay.
    Seasoned Citizen NAZ's Avatar
    Do you really want to mount the firewall permanently? If so, consider 3M Panel Bond.
    Myself, anything that's not welded I want removable. I used 10-32 button head screws to mount my firewall, floor boards, and all the rest of the tin work.
    Apr 2019
    Milford NH
    And I'm guessing you had no panel rattles
    Thank you for your time and info.
    If I was worried about rattling I'd use thin self adhesive weather strip like available from McMaster-Carr https://www.mcmaster.com/93375K607 or a bead of silicone.
    Apr 2019
    Milford NH
    I ended up using a little bit of silicone. After securing it wit the 10-32 button head screws and rivets. It came out nice and solid.
