Results 1 to 4 of 4
Thread: T-56 Super Magnum 6-Speed in '35 HRT
    Senior Member karlos's Avatar
    Littleton, CO
    Did a forum search but nothing turned up. My apologies if this has been addressed before.
    Looking to save a few $$ by going with an LS3/T-56 engine and transmission package. I don't see the T-56 listed as an option on the FFR build sheet for the '35 Hot Rod Truck. Anybody successfully used the T-56 Super Magnum 6-Speed in the HRT? If so, what modifications are required?
    Thanks.
    -Karl
    MKIV Roadster #8641
    Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
    Ford Racing Z427 w/ Pro-M Sequential Port EFI System
    TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
    Miller Customs Bodywork & Paint
    Senior Member DamnYankee's Avatar
    Port St Lucie, FL
    I am doing LS3 and T56 right now with mine. Had first start last week, check my build thread for some details on oil pan replacement.
    https://thefactoryfiveforum.com/show...l=1#post364389
    The LS option from FFR provided the correct mounts and Hooker exhaust manifolds. Everything fit. Only thing I had to modify was get the driveshaft shortened.
    Littleton, CO
    Geez, not sure how I missed this. Was aware of your build thread but somehow missed the T56 detail. Your build looks very nicely done and is spec'd similarly to what I intend to do. Thank you!
    MKIV Roadster #8641
    Bourne-Cape Cod, MA
    Quote Originally Posted by DamnYankee View Post
    Yep, as Damn Yankee stated driveshaft is the only change, We put one in the Red Barrett Jackson pickup with no issues... Its tight under the tranny tunnel , but it fits.
    FFinisher/AKA RE63
