Looking at Don Payne's PDF's of the passenger footbox mod drawings. Does anyone have a link to the drawings in full scale that can be printed at a copy / print shop? The only ones I see are for 8 1/2 X 12.
Cheers
Cheers
I recommend you make some cardboard templates based on those dimensions & tape them into place on your car. When I did mine I found that a couple of dimensions required “adjustment” to the tune of 1/2” (on the outside wall & front panels if I recall correctly). You’ll also be able to better match the curve where the inside panel meets the 4” tube on the inside panel.
IMG_2116 by jhsitton, on Flickr
MK IV Roadster #8631
