Thread: Brake light help please
    Mark Eaton's Avatar
    Medford, Oregon
    My brake lights are always on and when I push the pedal they go off. Seems like it should be a simple solution, probably a problem with how I wired the switch? I tried moving the leads on the switch to the position shown and I got no lights at all. I also switched their respective positions and nothing changed. Any ideas? Thanks!
    Mark,
    I had a similar issue when I first wired my car; brake lights working opposite the way they should. Moving the wires to the set of connectors shown with your yellow arrow corrected that. If you've done that and the brake lights don't come on at all, be sure the switch is adjusted so that as the pedal is released the button fully extends. The other possibility is that the switch is bad.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  3. Thanks Mark Eaton thanked for this post
    O'Fallon, MO
    Thats not a brake light switch, that's the clutch safety switch. Unless they changed switch design
    Rich,
    My kit shipped with two of the switches shown. One set of leads is used to operate as the clutch switch, and the other set as the brake light switch.
    Legal: 1/30/2020
    Elk Grove, NorCal
    Mark
    Like Papa said; change to the other set of connectors. I had the same issue. The assembly manual is wrong.
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
    Quote Originally Posted by Vspeeds View Post
    Mark
    Good point! I originally wired per the picture in my previous post, but that was not correct. After switching to the other set of connectors, the circuit worked as intended. I don't have my car here and couldn't recall which connectors worked, but it was opposite the on when the pedal was not pressed condition.
    Legal: 1/30/2020
    Mark Eaton's Avatar
    Medford, Oregon
    thanks guys, switching to the other set of connectors worked!
