Vspeeds
Mark
Like Papa said; change to the other set of connectors. I had the same issue. The assembly manual is wrong.
Good point! I originally wired per the picture in my previous post, but that was not correct. After switching to the other set of connectors, the circuit worked as intended. I don't have my car here and couldn't recall which connectors worked, but it was opposite the on when the pedal was not pressed condition.
