Thanks Thanks:  2
Results 1 to 9 of 9
Thread: Another wiring question, Flashers
    Mark Eaton's Avatar
    Medford, Oregon
    The good news is that all my lights seem to work! However, my turns signals and Hazards don't "flash". should I just replace these flasher things?
    Mark
    Mark
    I doubt that both flasher relays are bad. Are all the lights connected, or are you just checking the wires for current? There needs to be a load on the circuit for the flashers to work.
    Port Charlotte, FL
    Dave is absolutely right. If you switched over to LEDs, you’ll have to get the LED flashers.
    Henry
    Mark Eaton's Avatar
    Medford, Oregon
    Thanks Dave, All the lights are connected and light up as they should. They just don't flash.
    Mark
    Mark Eaton's Avatar
    Medford, Oregon
    Quote Originally Posted by 65 Cobra Dude View Post
    Henry
    Thanks Henry, that must be the problem. I am using LEDs. I don't suppose you happen to know what the part number is on LED flasher?
    Here are a couple I found on Amazon:
    https://www.amazon.com/Heavy-Compati...12-spons&psc=1
    https://www.amazon.com/CEC-Industrie...0995&s=gateway
    Just search for "no load 2-pin turn signal flasher"
    Mark Eaton's Avatar
    Medford, Oregon
    Thanks Dave!
    Port Charlotte, FL
    Sorry, I was on a plane Mark. Dave is right (again)! You can also go into any parts store and ask for a 2 pin LED flasher. Most have a wire coming out the top that needs to be grounded.
    Henry
  9. Thanks Mark Eaton thanked for this post
  10. #9
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    I'm using something similar to these units from NAPA
    In case you're interested, here's why your original flashers didn't work...
    The supplied flashers are "thermal". They rely upon the load of conventional bulbs to heat a bi-metal strip inside. The strip heats up, bends out of the way (breaking connection), and the lights go out. The strip cools, springs back (making connection) lights are on... repeat.
    LED's don't draw enough current to heat up the strip - so it never breaks the circuit.
    The "electronic" flashers are basically a timer circuit that fires a relay. They are not load dependent to operate. It sees +12 on the input and it starts timing an cycling the output.
    John D. - Minneapolis 'Burbs
  11. Thanks Mark Eaton thanked for this post
