Thanks Thanks:  4
Likes Likes:  4
Results 1 to 14 of 14
Thread: Wheel alignment specs
    Cobra Addict AtlantaCobra's Avatar
    May 2019
    Duluth, GA
    Hey folks, if this has been asked before, please forgive me.
    Does anyone know the alignment specs for our Cobra's? I stopped by my mechanic to ask if he could do an alignment for me and he said it would be helpful if I could get the specs of where it should be. Any thoughts? Thanks guys!
    -Greg
    Jan 2018
    Twin Cities, MN
    Should be in the back of your manual. Otherwise, look up FixIt and he just had his done and likes it. He posted the alignment sheet.
  3. Thanks AtlantaCobra thanked for this post
    Manual steering:
    .5 to .75 degree negative camber
    3.5 to 4 degrees positive caster
    3/32" total toe in
    Power steering:
    7 to 8 degrees positive caster
    3/32" total toe in
    Note that depending on which upper control arms and spindles you have it may be necessary to use alternate adjuster sleeves or modify the ones you have.
  5. Thanks AtlantaCobra thanked for this post
  6. #4
    Heart of Dixie, Alabama
    I can look in the manual when the time comes, but this thread should include the specs for IRS.
  7. #5
    Have done mine exactly per the manual. 2015+ Mustang based IRS:
    0.5 to 0.75 degree negative camber
    1/8" total toe in
  8. Thanks AtlantaCobra thanked for this post
  9. #6
    BadAsp427's Avatar
    Greeneville, TN
    MK4 Alignment Spec w/ IRS numbers as well
    Here are the spec according to FF Build Manual April 2018 Rev 4N
  10. Thanks AtlantaCobra thanked for this post
  11. #7
    I like a bit more toe in (helps prevent "dartiness"). Unless you're Ralph Button you'll never notice the minimally increased tire wear.
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    Does the the power specs. Include electric power setup?
    Walt
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
  13. #9
    Janesville, WI
    Anyone ever use toe out?
  14. #10
    Quote Originally Posted by Walt View Post
    Walt
    Yes.
    Quote Originally Posted by Packer fan View Post
    Serious track guys will go toe out for more bite at turn in but it greatly reduces self centering and straight line stability (hence my comment above regarding dartiness). Toe out is not recommended for a street car.
    Advanced search works really well. We really don't need a new thread on alignment every month.
  16. #12
    O'Fallon, MO
    Or, I don't know, look in the manual?????
  17. #13
    Why did I just think of this?
    https://youtu.be/PpgGwGIqccc
  18. Likes CFranks, Ducky2009, rsw81, SSNK4US liked this post
  19. #14
    I So Miss The Muppet Show, My Youth, High School & Most Of My Hair!
