Suspension help !!!
Need some input from the experienced builders here.
Back story on my MK2.
Built using a fox body donor - replaced/upgraded over the years.
I have just done a big list over the last 2 years (heat/def), drop butt mod, dual roll bars, Kirkey seats, rewired new Painless, pwr brakes.
Car was driven for a year, then did the 5 lug conversion and Halibrands ( North Racecars parts) - just over 3K on the car with this set up.
We are putting the body on and a friend pointed out what he calls "a problem".
I never noticed, but here are the pictures of the issue
Drivers side ball joint / UCA
looks ok to me, seems to be enough clearance.
Passenger side
WOW - again, I never noticed - seems way too close.
I have never leaned into it hard enough to flex the tire into the joint.
What can I do to remedy this ? - these are the 15x8 wheels from NorthRacecars.
These are 235/60/15 tires running 23lb of air, alignment had no issues.
Any input is appreciated. I would like to correct this before putting it back on the road.
Be safe,
"E"
