Thread: 2105 IRS Emergency Brake effort
    Feb 2017
    Looking for others experiences here -
    Installed the 2015 IRS w factory brakes,factory e-brake cables, and a lokar handle. factory cables connected to the lokar handle directly, and in line w the handle (no mechanism to multiply force / reduce travel). Factory mounting for the calipers - did not use the F5R relocating bracket (what is its purpose anyway? Didn't realize it existed until mine were installed so didn't bother)
    My problem is that it seems as though I have minimal E-brake grip even if I pull so hard on the handle I am fearful it may bend! If I give it a good hard pull while going down the road I can feel the brakes being applied, but a good downshift would be more effective!
    I assume this is because the factory system uses a foot pedal for activation, with lots more force being applied than my wimpy arm can manage. What
    have others with this setup experienced? Just trying to decide if there is an improvement to be made or if this is as good as it gets.
    Also - how about the Wilwood setup for the IRS - are those folks able to get more stopping power from the E-brake?
    Greg
    Quote Originally Posted by frd2 View Post
    ...how about the Wilwood setup for the IRS - are those folks able to get more stopping power from the E-brake?
    Can't help you with the factory brakes. Haven't tried them, but seems should work better than your experience. But to your Wilwood question, the 2015+ IRS upgrade Wilwood setup with the separate mechanical e-brake caliper works great. I guess they should since they're kinda pricey to say the least. Locks the wheels hard without big effort. Basically just tighten the cables, and they do their thing. I've only used them with the FFR e-brake handle. Also haven't used them while in motion, but quite confident something would happen. When parked, the car won't budge.
  3. Thanks Paul2STL thanked for this post
    O'Fallon, MO
    It's a parking brake, not designed to be used in an emergency to stop the car. Does it hold the car from moving when parked?
    Feb 2017
    It holds when parked to stop it from rolling up hill but not as sure about downhill! In all seriousness I think 2 men could push it.
    Senior Member brewha's Avatar
    Aug 2013
    Somers, Ct
    In Ct. the make you do a dump test of the clutch with engine running and emergency brake on. The engine needs to stall and the car not move. I’ve been practicing with anticipation going through this test when I register. I’ve like others found the rear pads totally ineffective at even slowing down the vehicle. Changing to a more aggressive pad will probably solve your issue.
    Btw... the only way I can pass this test is to lower rpm of the motor to 700.
    Mark4 - 331 Stroker - Fitech 600 -TKO600 - Moser 3.55
    Heart of Dixie, Alabama
    Put it in 3rd gear, they will never notice.
    Feb 2017
    Hawk pads not oem already.
