65 Coupe Headlight Covers
Head light Cover Brackets.JPGHeadlight Cover Bracket (2).JPGHeadlight Cover Hardware.JPG
Took a little different approach to the FFR supplied sheet metal brackets for the headlight covers. Superformance uses a similar attachment and all parts are from Mcmaster Carr.
The threaded stud end needs to be threaded up to the top, a simple task. I shortened the threaded rod and drilled and tapped the fiberglass. I plan on using a small plastic washer between the bracket and the cover.
Now if someone has a recommendation on shaping the covers to size, I would greatly appreciate any tips.
