Results 1 to 10 of 10
Thread: koni coil over spanner wrench
    having trouble finding a spanner wrench to adjust the springs on mk iv here in northern michigan. any body have a good idea or source to buy the wrench?
    thanks for the help!
    No tool needed, simply raise the car so that the springs are relaxed and you can turn the adjuster rings by hand (as long as nobody overtightened the setscrews).
  3. Likes BEAR-AvHistory liked this post
    Jax Beach, FL
    if you need something, a drift punch or a small Phillips screwdriver will do it.
    Senior Member CFranks's Avatar
    Mar 2018
    Berwyn, PA
    If none of the above options work, Breeze has a spanner for Konis: https://www.breezeautomotive.com/sho...ng-adjustment/
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Koni sells a spanner for their shocks. It's P/N 7029170080. IIRC, it's like $18.
    Jax Beach, FL
    When I first read that, I thought the part number was IIRC. I was thinking "Look at the big brain on John"!
    That wrench won't work on our FFR provided Koni shocks. You need the pin type, or just do as Jeff said and unload the springs and turn them by hand. If you don't believe me, I'll sell you the one collecting dust in my garage.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I guess I should clarify which Koni shocks I'm referring to. I have the silver double-adjustable Koni's and the wrench I mentioned works perfectly on those.
  10. #9
    Copperhill, TN
    I used a rubber strap wrench.
  11. #10
    Jun 2019
    Quote Originally Posted by davespencer View Post
    Click this link to view more tools.
    You can find on Amazon or Summit Racing Equipment to find the wrench.
