Thread: Is my driveshaft too long?
    Mar 2017
    Lafayette, CA
    So I was having difficulty installing the driveshaft because it would contact the IRS differential. I ended up needing to lift up the engine to get it installed. I got it all bolted down and even the driveshaft safety loop installed, when I looked at the inventory list that FFR sent stating that the driveshaft they sent me was a 31 spline 9.25". My original order form listed a driveshaft that was 8.375". Oops! Did they send me the wrong driveshaft? Do I need to take it all out? Those bolts now have blue loctite on them... Here are the photos below. I have a Blueprint 427 with IRS. The gap on the yolk is about 1/4 inch. From what I have read, that should be more like 3/4 - 1 inch. If my only problem with this setup is that I would need to lift the engine again if I have a problem with the driveshaft in the future, then I may just leave it alone. But if there will be interference problems with a gap this short, then it would make sense to correct it now.
    Thanks for your advice on this!
    -David
    MK4 Roadster #9138
    Blueprint 427 with Sniper EFI, TKO600, IRS, complete kit
    https://thefactoryfiveforum.com/show...8-Build-Thread
    With IRS, the diff doesn't move. So there shouldn't be any operational issues. Like you explained, the main issue would be removing in case of required repair/replacement. The more normal 3/4 - 1 inch of exposed slip yoke allows it to move with a solid axle, and also provides the needed clearance to push the slip yoke all the way in and then drop out the driveshaft without taking anything else apart.
    I'd leave it as is.
    O'Fallon, MO
    Looks like you have 3/4", measure from the transmission, not the dust seal lip. It's fine just as it is.
    Mar 2017
    Lafayette, CA
    Perfect, thanks guys!! I will move forward!
    MK4 Roadster #9138
