Thanks Thanks:  2
Likes Likes:  2
Results 1 to 23 of 23
Thread: 32 deluxe grill -updated with pictures
    Senior Member sethmark's Avatar
    Virginia International Raceway
    Has anyone assembled a 32 deluxe grill yet? I’m missing parts according to the POL, but it doesn’t appear that way in the manual. I’d like to see how it mounts and what mounts to it.
    Thanks!
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
    To answer my own question, I spoke with factory five today and the 32 grill is totally different. There are a number of parts and components for assembling the grill and condenser that do not cross over. Considering that I apparently have one of the early ones, I will post as I assemble. Currently I’m missing a bunch of components.
    Titled 2-28-20
    MkI.IV 2643k
    Installation pics...
    ‘Installing grill in frame... I prefer using a 3/8 belt sander to notch the holes than using a drill bit to hog out the holes.
    Titled 2-28-20
    MkI.IV 2643k
    Condenser and radiator sandwich. Note the instructions don’t call out drilling the lower radiator holes yet....which you must do at the beginning of the project.
    Titled 2-28-20
    MkI.IV 2643k
    All assembled loosely the first time.
    Titled 2-28-20
    MkI.IV 2643k
  6. Thanks erlihemi thanked for this post
    The stack....
    Titled 2-28-20
    MkI.IV 2643k
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    Go to Factoryfive.com/instructions. There is an update you can download for the 32 deluxe nose installation.
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
    Quote Originally Posted by RBBJ 32 HOTROD View Post
    There are some errors in those instructions. I told Jim.
    Titled 2-28-20
    MkI.IV 2643k
  10. #9
    Seasoned Citizen NAZ's Avatar
    You didn't by chance weigh the new grill & radiator assembly? It appears to have a fiberglass shell that I expect is much lighter than the cast aluminum 33 style.
  11. #10
    I didn’t, but I most certainly can. It does however have the condenser and fan attached. If you want something specific, ask me and I’ll be happy to get it for you.
    Titled 2-28-20
    MkI.IV 2643k
  12. #11
    That's great! Just need the weight of the grill, shell, and empty radiator. The 33 style is a bit porky and shedding front end weight would be an advantage on my car.
  13. #12
    Complete assembly is 39#. The grill and shell weigh about 5#. Grill is just chromed sheet metal....
    Titled 2-28-20
    MkI.IV 2643k
  14. #13
    Thanks! Wow, surprised it weighs that much.
  15. #14
    The bracket setup is fairly elaborate...
    Titled 2-28-20
    MkI.IV 2643k
  16. #15
    Jan 2019
    How did you route the lower radiator hose?
  17. #16
    90* elbow off the radiator. Between the Coilovers and Bent up a piece of stainless pipe and routed it to the water pump. Can’t find a good picture.
    Titled 2-28-20
    MkI.IV 2643k
  18. #17
    This is early in the fab process.
    Titled 2-28-20
    MkI.IV 2643k
  19. #18
    Jan 2019
    Quote Originally Posted by sethmark View Post
    Thanks. Seems like a bit of good fab work you had to do.
    its a **** location for the connection. I wrestled with the metal hose for about an hour before packing it up for the night.
    I like the set up. Was this standard material you could get on JEGS or Summit?
  20. #19
    It wasn’t bad at all. I bought the stainless tubing from Summit with a handful of 45s and 90s. I used the corrugated to set up my angles, then transferred it to tubing.
    Titled 2-28-20
    MkI.IV 2643k
  21. Thanks Higgi56 thanked for this post
    Likes Higgi56 liked this post
  22. #20
    Jan 2019
    By the way, I had the horns where the lower connection was and pulled them. Where did you move the horns to?
  23. #21
    Split collar on frame.
    Titled 2-28-20
    MkI.IV 2643k
  24. Likes JOP33 liked this post
  25. #22
    Jan 2019
    brilliant solution. I like simple and removable.
    the only thing i dont like about the radiator is no trans cooler. they sent me the radiator for the original grill and it had one built it. Oh well. more money for the speed shops I guess.
  26. #23
    Mar 2020
    what does the complete setup cost
