Thread: Gen 2 with SBC & 700 R4 exhaust problems
    Senior Member colsen23153's Avatar
    Jan 2019
    Sandy Hook, Virginia
    Has anyone with a Gen 2 and SBC and 700 R4 trans mounted the exhaust from FFR? Did you have any problems?
    Here is my problem. 100_2275.JPG Any suggestions?
    '33 Hot Rod Chassis #1118, Gen 2, hard top, bike fenders, AC, electric steering. BluePrint Engines Chevy 383 Fuel Injected with the 700R4 transmission 8.8" rear 3.55.
    Little Rock, AR
    I have the same set up. I had to move the engine back to clear the front pulley so I went with the Summit SNH-CC11-P headers. https://www.summitracing.com/search?...ord=snh-cc11-p
    The exhaust didn't align great throughout so I ended up taking mine to a performance exhaust shop to have it custom installed.
    Nov 2015
    Elverta, CA
    We had a problem with mis-made pipes for the sbf configuration a few years ago. The pipes were made backwards and ffr had to replace them. You may have similar problem so call Tony and the boys to check..
    Jan 2019
    I had a reply from FFR that they are looking into the problem. Seams I'm not the only one. They said they would make something for me to get it to work and send them to me. That was a week ago but that's OK. If what they send me works it's worth the wait. I want to Go-Kart it but not with open headers.
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    My headers came with collectors with removable flanges. I used those extra gaskets and longer bolts to lower the down tubes enough for clearance. 20190910_194543.jpg
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
    May 2018
    Pinckney, MI
    That is exactly the solution I'm looking at as well. I need to still check the fit, but I think that will do it and provide enough space. Gaskets or welding the spacers with a small gap may help...
    - Peterh226 #1134
