Results 1 to 12 of 12
Thread: My new front brake light !
    herb fraser's Avatar
    Lightbulb My new front brake light !
    So here is the issue. When my headlights are on and I step on my brake not only do the rear brake lights come on , but the front amber lights also come on ? This only happened when my headlight are on and not when they are off.
    Any advise would be great !
    Thanks Herb
    Senior Member weendoggy's Avatar
    Aptos, CA
    I'm going to ask how you're turn signals are wired, because if you're saying the "t/s filament side" of the front amber light is coming on, it's feeding from the brake / t/s side.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    Quote Originally Posted by weendoggy View Post
    somehow it must be, however it only happenes when the headlight switch is on
    Bourne-Cape Cod, MA
    Quote Originally Posted by herb fraser View Post
    I am away on vacation. But I can tell you that in the wiring harness instructions it tells you to cut the wires to the front turn signals at the connection that would normally be used for the roadster. Since the hot rod and pickup use the Ididit column these wires should not be connected.
    If this doesn’t make sense I can send more clarity when I get home
    On Friday 7/5.
    FFinisher/AKA RE63
    Bourne-Cape Cod, MA
    On Friday 7/5.
    FFinisher/AKA RE63
    Quote Originally Posted by FFinisher View Post
    On Friday 7/5.
    Thanks ! that certainly seems like it. will et you know tomorrow, Thanks herb
    When all else fails read the book !. tells you right in the manual to cut the yellow and white wire to avoid this , So all is well. Herb
    Loveland, CO
    Herb, we all have the same problems. I read the manual, but didn’t think it applied to the Idit steering column wiring used in the pickup. Studied the wiring manual for hours trying to make sense of it. Finally cut the wires in an abundance of caution. Haven’t tried lights yet, but evidently necessary.
    Ralph
    When all else fails read the book...
    Or listen to Ron because he knows more than the book
    Bourne-Cape Cod, MA
    Herb, just let me know if you have any other issues- I am happy to help if I can.
    FFinisher/AKA RE63
    thanks so much, Herb
    Exactly !
    Thanks !
