Results 1 to 2 of 2
Thread: Accelerator Pedal
    NY
    Accelerator Pedal
    Building Gen 3 and cant use Russ's pedal, any suggestions for what to use? Also, using Fortes linkage if that matters, thanks
    Edmonton Alberta
    I used the kit pedal and Fortes linkage on mine. Mine is an early Gen 3 so they may have updated it. I think the pedal mount is drilled for the Ford Coyote pedal. I had to relocate the pedal to ftt the linkage and drill new mouning holes for it.
    Don't know why Russ's pedal won't fit, I have used a numer of his parts but not the pedal.
    David W
    Mkll 4874 built in 2004
