Results 1 to 2 of 2
Thread: SOLD Front Koni Coil Over Shocks & 500# Springs Set SOLD
    BadAsp427's Avatar
    Greeneville, TN
    SOLD
    I'm selling these for $400 + shipping.
    I have a brand new in the box set of Koni Front Coil Over Shock set for sale. This includes two shocks, two 500# springs, the collars and adjustment sleeves. After an email or two to FF, it has been confirmed that these with the 500# are the same as part #14676 currently listed on the factory five parts site for $499. CLICK HERE for official description.
    #14676 - KONI FRONT COIL OVER RETRO-FIT KITS
    These coil-over shock kits were custom engineered by Koni in conjunction with FFR engineers through computer modeling, track testing, and use of Koni’s own testing circuit. These efforts resulted in a great balance between street and track driving. A smooth ride is maintained on the street, and the performance numbers on the track are truly impressive. You’ll find that these shocks will give your car a very precise feel in its handling. They are rebound adjustable for those that desire to do some fine tuning of their own. The shock body has a red finish, and the shaft is 0.539” in diameter. The larger size of the damper body requires the use of 2.5”diameter springs, and in the concern for weight and fitment we chose an 8” spring height. With the change in dampening, we also found some ride and handling improvements by additionally changing the spring rates. As a result the solid axle coil-over kits include 350lb springs, front coil-over kits include 500lb springs, and IRS coil-over kits include 750lb springs.
    Tech Notes:
    - Retro-fit coil-over kits work with all FFR Coupe, and Roadster kits using the new Factory Five front lower control arms or stock Mustang arms.
    - These are same coil-overs used on the front of the '33 Hot Rod
    - These do not fit the old Factory Five front lower control arms (pre-August 2003).
  2. Likes shmelty liked this post
    BadAsp427's Avatar
    Greeneville, TN
    Sold
