Does anyone know what the two hole vertical bracket pictured in the foreground is used for? I'm thinking its for a parking brake application, but just guessing. Nothing about it I could find in the Roadster Complete Manual.
MkIV Complete Kit #9423, Gen 3 Coyote, TKO-600, IRS Torsen 3.73, Wilwoods, DA Konis - Delivered 9/14/18
That bracket is used for the emergency brake cables for those using Mustangs as a source of parts. I actually bought a 1995 brake lever and different brake cables to use in my build as I didn’t like the brake cables running under the frame bar. It has worked fine so far.
Mark4 - 331 Stroker - Fitech 600 -TKO600 - Moser 3.55
Thanks brewha. Yeah, i'm not crazy about the way the manual shows the cable routing either. Plan on doing a similar alteration that others have done going over the tube instead of under.
I did the same over the tube edwardb has a great thread on it
That bracket can still play a roll with the cables, even if they are run over the 4" tube, so don't cut it off.
Right on Bill, I was thinking I could still possibly use it.
