Out of Sight Audio
Results 1 to 2 of 2
Thread: Free Stuff in Southern Calif.
    So. Bay (So. Calif.)
    Two boxes of left over parts, mostly FFR 'complete kit' parts, that I didn't use. All new, some were mounted but taken off and not used.
    I'm in South Bay (southern Calif., Palos Verdes/San Pedro), so come by and take them all. I hate to just throw them away.
    If you need just a single part or 2, and you are not in the area, we can work out some sort of shipping.
    Best way to get in touch is my email [email protected], 'cause I usually miss that little notification flag at the top.
    Here's a partial list (from the top of my head)...
    throttle pedal
    Headlight bulbs, Wagener
    hood pin set
    fan belt (Gates K060620)
    idler pulley
    radiator cooling fan mounts (aluminum straps, and the push thru plastic pins)
    battery hold down kit
    conical air filter Gone
    clutch cable, bulkhead mount, pedal cams, and some hardware Gone
    fender bullet mirror Gone
    MSD 6-AL ignition Gone
    oil filter relocate kit Gone
    fuel tank pickup (non FI I believe) Gone
    fuel filter Gone
    misc battery cables, grounding cables Gone
    the flat fender side louvers (and angles) Gone
    roll bar trim rings Gone
    remote brake reservoir Gone
    ignition key switch and keys Gone
    dash toggle switches (4 or 5 of them I think) Gone
    coolant T filler neck Gone
    side pipe hangers Gone
    flashers Gone
    dash indicator lights (red, blue, 2x green) Gone
    Vintage Air manual heater valve with control (knob, cable, switch) Gone
    Vintage Air defroster vents and trims) Gone
    speedometer pickup (with 2 gear ratios) Gone
    quick-jack bumpers, front and rear, raw Gone
    starter solenoid (panel/firewall mount) Gone
    I've got quite a bit of aluminum sheet, angle, bar stock left over as well. You'll have to pick through that.
    Also a fair amount of fasteners as well.
    I think that's about it.
    Last edited by boat737; 07-28-2019 at 06:37 PM. Reason: Marked off the claimed items
    Alright, last chance, for the last few items.
    Going once, going twice.....
    I'll give it a week, then off the the trash bin they go.
