Likes Likes:  2
Thread: Cobra Earl CNC Machined Thermostat housing
    Mar 2014
    Pass Christian, Mississippi
    New never been used Cobra Earl Thermostat housing. Description here: https://tdmotion.com/product/427w-fo...t-housing-kit/
    302 – 427w Ford Ultra Thermostat Housing Kit
    This CNC Machined thermostat Housing Assy entails 4 pieces. A lower 90 degree Housing. Mid Housing with the 1.5 Radiator hose outlet, Fill Neck and Billet Aluminum 16lbs Radiator Cap. Small Block Fords are notorious for trapping air in the cooling system which leads to “Hot Spots” in the cooling System.
    In some applications the intake manifold is the highest point in the cooling system. This filler neck kit allows the system to be filled from the intake manifold to minimize air pockets. Features provisions for two 1/4″ NPT intake manifold bypass fittings, a provision for 1/2″ NPT sensor fitting and left or right radiator hose orientation. CNC machined from 6061 billet aluminum. Includes an o-ring seal fill neck, 1/8″ NPT x 5/16″ hose overflow fitting, thermostat gasket and stainless hardware.
    Sells now for $347.95. Asking $165. A beautiful addition to your 302-427. Prefer Pay Pal and PM me.
    MK IV complete kit delivered August 21st, 2014. Ford Racing 427w with X heads. IRS. Upgraded Wilwoods, 6 piston front and 4 rear. Tremec t600 and Ram Dual clutch. Holley Terminator EFI.
    Senior Member SSNK4US's Avatar
    Bakersfield, CA
    Just out of curiosity how come your not going to use it? I’ve seen and thought about one of those quite a bit. Has anyone had any experience with one of those? HECK of a deal at $165!!!
    Kurt
    Build thread
    I had one on my #7750 build. Very nice improvement from the usual SBF thermostat housing setup plus eliminates the in-line T-filler. Highly recommended. This is a smoking deal.
  4. Likes SSNK4US liked this post
    Mar 2014
    Been so long not quite sure. What i have is fine. Cleaning out like most of us on here. When I looked for Cobra Earl I saw his products are not available from him directly. Knew he had health problems some time ago. Edward B good seeing you still around.
  6. Thanks SSNK4US thanked for this post
  7. #5
    Bakersfield, CA
    Thanks Paul that’s what I was thinking. I wish I had a spare $165 laying around... I’m sure I’ll pay full pop later in life
    Kurt
    Build thread
  8. #6
    Mar 2014
    Make me an offer. Saves me the time of listing on EBAY
    Quote Originally Posted by SSNK4US View Post
    Kurt
    Make me an offer . GLad to see someone on here get it and save me the hassle of ebay.
  9. #7
    Bakersfield, CA
    Hi Paul, this is Cathy Kurts wife. Will you take $150 for it?
    I know he really wants it, I would do anything to bring a smile
    to his face.
    P.S. I’m pretty impressed with myself for finding
    your post..
    Build thread
  10. #8
    Bakersfield, CA
    Best wife in the world!!!
    Sorry she got the name wrong Paul. Probably because I’ve talk to her about you and shown her your stuff for years!!!
    pcww PM sent
    Kurt
    Build thread
  11. #9
    Mar 2018
    Maryland
    pm sent
