Thread: DART Bolts or Studs
    Northern VA
    DART Bolts or Studs
    Hey Everyone,
    Piecing everything together for my Dart SHP 363. I am at a crossroads here. Do I use the main bolts that DART supplied (grade 8), or do I upgrade to ARP studs for the mains. I most likely wont have to align hone if I stick with the current hardware. Switching will most definitely require a line bore/align hone.
    DART said these bolts are good for 600 hp. I think my build will be around 450. Possibly 500 in the future if I go with bigger heads.
    EDIT: one more thing to add. Machine shop thinks I will be just fine with the supplied bolts.
    What say you engine guru's?
    Scottie
    Hey Mr. Scott,
    Like you I'm no Guru, but we used the bolts that came with the Dart SHP block to build our 383.
    The engine is making somewhere around 450 HP, possibly 10-25 more.
    Northern VA
    Hey Mr. Scott,
    Thanks Steve!
    Seasoned Citizen NAZ's Avatar
    The cap screws will be fine. I just built a Dart Little M block SBC that the bottom end is good for 1500 HP and more than 8000 RPM, used ARP cap screws. However, when it comes to heads I use ARP studs to get more clamping force as this is a nitrous engine.
    Northern VA
    So NAZ, just so I am clear - Stick with the dart bolts for the main caps. Correct?
    Yes. Each one of those 1/2-13 G-8 cap screws provide >12,000 lbs of clamping force.
    BTW, the rod bolts are a much higher stressed fastener than main cap fasteners. There's where you should pay close attention to fastener strength.
    Northern VA
    You are the man. Thank you sir
