Results 1 to 9 of 9
Thread: DSS Axles
    Jan 2019
    DSS Axles
    6 Speed 2011 to 2006 STI level 3.9 axles good for 850 hp. $1379 quote today.
    Sgt.Gator's Avatar
    Bend, Oregon
    Quote Originally Posted by Brd.Prey View Post
    I'm not sure what you are saying or asking, but if you're looking for a better price I might be able to beat that. Do you have a part number? Front or Rear? Or are these special order for our 818 conversion?
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Jan 2019
    I was just posting the quote so other people would have a price idea. These are special order for the 818 with 6 speed inner and STI hub outer. Please someone in the know confirm, I counted it like 10 times but I got 25 on the diff and 27 on the hub.
    Leesburg, VA
    Not sure about 06, but 04 sti rear hubs are indeed 27 spline.
    Sgt.Gator's Avatar
    Bend, Oregon
    The 04 STI uses the 5 x 100 hubs. Are using the 5 x 100 WRX/04 STI hubs? (It sounds like you are). If you have the 06 STI hubs they 5 x 114.3 and will be different. Make sure DSS is not using the 05+ STI outer splines.
    Personally I use the CV axles as fusible links. They are much cheaper and faster to replace than the tranny. So I stay with OEM/FF CV/bars. Although that didn't work on my last build post!
    818R ICSCC SPM
    Jan 2019
    I am using 06 STI spindles front and rear I have 5x114.3. SO I want DSS to use the 05+STI outer splines right??????
    Sgt.Gator's Avatar
    Bend, Oregon
    818R ICSCC SPM
    Jan 2019
    Separate question Sgt Gator, Ibought your trans seal driver and guide. These work on the 6 speed also right?
    Sgt.Gator's Avatar
    Bend, Oregon
    Yes, same sizes.
    818R ICSCC SPM
  10. Thanks Brd.Prey thanked for this post
