While bleeding the basic kit rear brakes, brake fluid leaks out of the where emergency brake assembly enters the caliper body on the bottom side of the caliper. The leaking fluid is not coming out of the bleeder valve, brake lines, banjo fitting nor the brake line connection. When pressing on the brake, the brake fluid FLOWS out; not just a drip.
https://drive.google.com/open?id=0By...9iTFJkZjdPX0Vn
