Thread: Lost the nut from headlight switch
    Oct 2018
    So somehow I managed to loose the nut/screw that holds the light switch. FF is out of stock. Does anyone have an old/ not functioning switch they would be willing to part with. Or know what the part number is so I can order from someone else
    Nick
    Similar: https://www.ronfrancis.com/prodinfo.asp?number=HL%2D33. Could be used with/without trim rings. The headlight switches Ron Francis sells are the Delco style ones like FF uses. So expect it would fit.
    Oct 2018
    Senior Member brewha's Avatar
    Somers, Ct
    This is the actual whole switch from Ron Francis......https://www.ronfrancis.com/prodinfo.asp?number=HL%2D03.
    I had just replaced mine and threw away the old one. Just last week. Sorry
    Mark4 - 331 Stroker - Fitech 600 -TKO600 - Moser 3.55
