Results 1 to 4 of 4
Thread: United Stacker Trailer with 6000 lbs lift
    Newcastle, Wyoming
    2017 Custom Built United Stacker Trailer
    42637570-580-undefined.jpg42637614-748-undefined.jpg42637626-353-undefined.jpg42637645-437-undefined.jpg42637654-408-undefined.jpgNEW-2017-UNITED-26-ENCLOSED-STACKER-TRA.jpg
    Custom Built and Blacked Out for a very stealthy look. Stacker was built of for a display and is in like new - excellent condition with very low miles. I purchased the trailer in April 2017 and have only used it once since purchasing the stacker. I need to make some room for other items and decided to sell. You can haul you FF5 car and another to drive around while at the car show. Below are the specifications on the custom built - blacked out stacker trail we have for sale:
    2017 United 8.5X26 Super Hauler TAG Stacker
    MODEL: USH-8.526TR70
    8.5 WIDE BODY, CAST ALUMINUM CORNER, TAG FLAT TOP, TRIPLE AXLE
    AXLE:
    3 - 7000# ELECTRIC BRAKE w/6 INCH DROP TRIPLE SPREAD AXLES 5” SPREAD BETWEEN AXLES
    TIRES:
    USH UPGRADE 6 – 215/75R17.5 WITH BLACK INLAY, TIRE AND WHEEL UPGRADE 215/75R H RADIAL TIRE W/07 ALIMINUM WHEEL W. BLACK INLAY 9/16” STANLESS STEEL CAPPED LUGH NUTS WITH INTERIOR MOUNTED SPARE TIRE AND CARRIER
    HITCH:
    7-WAY MOULDED PLUG, BREAKAWAY KIT w/CHARGER, 25000# BOLT ON COUPLER
    HYDRULIC TOUNGE JACK 6000# WITH MANUAL OVERRIDE / EQUALIZER # TJ 8065 WITH 12 VOLT BATTERY, 2 SAFTEY CHAINS, TONGUE - 1 FOOT EXTENDED W/THIRD MEMBER
    FRAME:
    THIS TRAILER HAS A BEAVERTAIL, BACKER ON UNDERSIDE OF WING FOR 14” LED FLOOD LIGHT, 2” WIDE CORNER POSTS, 44 FEET OF E-TRACK, GEMINI 16FT – 6000 # 4 POST LIFT, HEAVY DUTY D RINGS, 8” I-BEAM FRAME, 1 PAIR HEAVY DUTY SCISSOR JACKS, 36” LONG RAMPS POWEDER COATED BLACK, ROOF BOWS 12IN OC, 5’ PLATFORM – CAR DECK / STORAGE, REAR WING OPTION, RECESSED FLOOR COMPARTMENT (SPARE WELL) SET UP WITH WINCH / ROLLER WITH FLIP UP DOOR, SKID ROLLERS 4 ½” WELDED TO FRAME, 26’ UPGRADE – 16” TO 12” ON CENTER CXM, 26’ WALL- NASCAR HATPOST-16” OC
    VENTS:
    1 PAIR – SALEM SIDEWALL VENT (2-WAY)
    INTERIOR:
    .030 SILVER ALUMINUM CEILING – ADDED LUAN BACKING UNDER PLATFORM,
    .030 SILVER ALUMINIM INTERIOR WALLS OVER 3/8 PLYWOOD WALLS, FULL HEIGHT FAΗADE 12” INTO REAR RAMP DOOR OPENING 9” DEEP .030 ALUMINUM, COVE TRIM, HEAVY DUTY BUILT IN D-RINGS RATED AT 5000#ON EACH CONER OF LIFT, RECESSED E-TRACK WELDED IN RATED AT 2300# AND TRIMED IN SMOOTH ALUMINUM (2) 26’ ROWS IN FLOOR STARTING AT REAR AND GOING FORWARD 48” APART, 14’ E-TRACK WELDED IN AND RATED AT 2300# TRIMED OUT IN .080 SMOOTH ALUMINUM, FLOOR Ύ” PLYWOOD WITH SMALL RAISED COIN FLOORING (BLACK) MAIN FLOOR-RAMP-AND PLATFORM, CARPETING ON WALL 36” TALL, WALLS – SCREWLESS ALUMINUM 30+ EXTRA HEIGHT
    12 VOLT ELECTRICAL:
    9 X 7 led SCENE LIGHTS , 12V BATTERY BOX FOR HYDRAULIC JACK-RS ABOVE PLATFORM ON SHELF, 12V BATTERY BOXFOR LIFT-RS ON PLATFORM, 12V BATTERY BOX IN WINCH COMPARTMENT FOR WINCH, 12V FLOOD LIGHT 14” LONG, LED CENTERED ON REAR WING, CLEARANCE AND TAIL LIGHTS FOR ENTIRE UNIT, 2 EA. LED PORCH LIGHTS, 4 EA. LED 4” ROUND RECESSED DOME LIGHTS (20) LEDS BOTTOM OF FAΗADE, 12 EA. 4” ROUND LED DOME LIGHTS (20) LEDS CENTERED UNDER PLATFORM ON SIDEWALLS, 1 PAIR BACKUP (DOCKING) LIGHTS, 22 EA. LED CLEARANCE LIGHTS, 3 PAIR EXTRA SET LED SURFACE MOUNT TAIL LIGHTS WITH CHROME TRIM UP HIGH ON DOOR, 1 PAIR MID SHIP TURN SIGNAL AMBER LEDS WITH BLACK TRIM, 3 EA. LED DOME LIGHTS RS IN FROMT OF JUMP DOOR, 3 EA. SIDE (6 TOTAL) OBLONG SURFACE MOUNT TAIL LIGHTS WITH BLACK TRIM, STERO WITH 4 SPEAKERS MP3/AM/FM/CD, EXTRA SPEAKER CNETERED UNDER FAΗADE, 2 EA. 12V 3 WAY SWITCH, 5 EA. 12V SINGLE WALL SWITCHES, 3 EA. TRICKLE CHARGER PACKAGE FOR EACH BATTERY, 12V SUPERWINCH 5500#
    EXTERIOR:
    BLACK OUT ON TRAILER – POWDER COAT ALL EXTERIOR TRIM, FLARES HARDWARE, CAST CORNERS, HITCH COVER AND ALL EXTERIOR ITEMS POSSIBLE, BLACK ALUMINUM FRONT CORNERS, BLACK ALUMINUM FRONT WRAP, .080 SMOOTH ALUMINUM 24” TALL ON FRONT POWEDER COATED BLACK, .050 ALUMINUM COLOR BLACK, GLUED EPOXY EXTERIOR ABOVE 30” IN HEIGHT -NOT TAPED, 6 EA. 23” SINGLE WHEEL FLARES FOR SPREAD AXEL CONFIGURATION, REAR WING OPTION, RECESSED TOP ALUMINUM EXTRUSIONS, ALUMINUM SEAMLESS WALK OF ROOF WITH 12” CENTER ROOF BOWS, 24” X 24” ROOF ESCAPE HATCH WITH GAS SHOCK INCLIDES LADDER, ALL EXTERIOR ALUMINUM IS SEAMLESS NO SCREWS
    DOORS:
    4’ flap – ALL ALUMINUM WITH DOCK BUMPERS (IPO PLYWOOD FLAP) 2 ALUMINUM GRAB HANDLES ON RAMP DOOR, BEAVERTAIL RAMP DOOR WITH SPRING AND FLAP, JUMP DOOR (THIS IS AN RV DOOR) 48” X 58”, RV DOOR 32” X 78” BLANK, RECESSED CAMLOCKS (REAR DOOR), RAMP DOOR – DOUBLE SPRING FOR HEAVIER RAMP DOOR
    CABINETS:
    ALUMINUM 8’ OVERHEAD SILVER, BATTERY SHELF 3/16” ALUMINUM POWDER COATED BLACK
    OPTIONS:
    GEMINI LIFT RAMP POCKET
    110V ELECTRICAL:
    50 AMP PANEL, 5 EA. 4’ LED LIGHTS (2) RIGHT SIDE (2) CS ON THE COVES SPACED EVENLY AND (1) CENTERED UNDER OVERHEAD CABINET, 50 AMP MOTORBASE PLUG, 110V RECEPTICAL FOR TRICKLE CHARGES, 110V GFI EXTERIOR, 7 EACH 110V INTERIOR DUPLEX RECEPTICALS, 2 110V 3-WAY SWITCHES
    Feb 2019
    Houston, TX
    Price?
    Newcastle, Wyoming
    Ajzride,
    Sorry for the later reply, had surgery in my jaw and was out of things for a few days. I may have a buyer lined up will know tomorrow but the asking price is $45,000.00 but will entertain reasonable offers.
    Newcastle, Wyoming
    This stacker trailer has been sold and is no longer available.
