0
0
2015 coyote question
Hello all new to the forum . Would like to ask for some help on 5.0
Coyote swap. Im kind of old school so dont know a lot about
newer coyote stuff. Purchased a complete motor and auto transmission with complete factory wiring harness dash cluster,brake pedal, steering column everything to run the motor. I have everything pluged in that can be pluged in. Also all the grounds coming out of the main harness are grounded back to battery. I have power to the under hood fuse box but none of the fuses are hot on the kick panel . The push start button is lit up ,shifter has power,but wont come out of park. Brake pedal connected and brake switch is made,still when you push button nothing happens. Have new batteries in fob and Pats has been turned off. Have power to starter. If anybody has any ideas i would appreciate it. Or maybe you could point me in the right direction. Thank you for looking. Joe
